Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
Baked GPU: Target Display Mode not working properly
Hi,
My iMac display died some weeks ago. It was a well known issue: several colored stripes on the screen (green in my case) and the iMac would not boot up.
After researching the problem I quickly diagnosed that it was the GPU that was failing. I found several posts online which suggest to try and bake the GPU in the oven for 10 minutes at 200 degree celsius.
While it was quite an operation, it worked. It took me about 5-6 hours to do. Fist opening up the iMac, removing the logic board, and finally removing and baking the GPU. I applied new thermal paste (Arctic Silver). Put the maschine together, and it worked, it booted again! I was so thrilled!
But then I tried to use the Target Display Mode to use the iMAc as a second screen for my MBP Late 2013, which has worked flawlessly last couple of years.
TDM works . The MBP sees the iMac. I am able to initiate with cmd + f2. The problem is that the display of the iMac keeps flashing/flickering and is not usable. I’m also able to use my imac to output sound, which sounds distorted/cracked. Yesterday, after some time, it even worked for some time, but after quitting/enabling TDM, it was broken again.
I’ve tried everything to get it back to work. Updating the OS’s, resetting SMC, VRAM etc this did not help.
What’s strange to me is that the iMac works perfectly (for as far as I can see right now). As a standalone computer that is. It boots, it displays, there is sound everything seems to work. Only TDM is not working.
I tried using Apple Hardware Test, but for some reason that keeps crashing on the memory test? I used 3rd party memory tests to see if that works, which it does. But AHT does not!
I just run Cinebench, which also worked and seems OK.
Is there anything I can try? I’m really wondering what the problem is because like I said, the machine works perfectly beside the TDM.
The only thing I can think of is the GPU failing somehow in TDM. I’m not sure how TDM works internally though. Buying another GPU might be an idea, but thats pretty expensive for this older machine (300 $ or so) and even with that it might not be te problem.
Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Nope your GPU is gone its time for a new GPU board:
  • AMD Radeon HD 6770 512 MB - 661-5967
  • AMD Radeon HD 6970 1 GB - 661-5968
  • AMD Radeon HD 6970 2 GB - 661-5969
This is still a very good system! I still have mine as my main work system. It’s worth saving.
Punteggio 2
5 Commenti:
Hi Dan. Ouch! Thats what I assumed to be the most logical indeed. Still very weird that the computer itself functions normally tho. Do you have experience with buying new / second hand GPU's like these? Any signs to look for? Are there newer cards available that Apple used in the replacement program? Thanks!
da
@alm0szt - Where are you? In Europe?
da
Yes I am! Netherlands. Found this one, but this one does not have the end numbers 661-5969 displayed in the listing.... (https://www.ebay.com/itm/Apple-iMac-27-A...)
da
I was going to aim you to TheBookYard in the UK GPU boards
da
Thanks Dan. The boards are out of stock ATM tho. And im still a bit hesitant that its the GPU again. Because 1: the machine works besides TDM 2: Apple Hardware Test wont run properly (cant even get in AHT anymore). Maybe the Logic Board is damaged somehow? Very frustrating issue after all the work nonetheless.
da
Aggiungi la tua risposta
alm0szt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 127
