Salta al contenuto principale
{A1989 / EMC3214} - Rilasciato nel luglio 2018, il MacBook Pro da 13" integra processori i5 e i7 quad-core e grafica integrata Intel Iris Plus.
199 Domande Visualizza tutte
Can the headphone jack on MacBook Pro 2018 be easily replaced?
Can the headphone jack on the macbook pro 2018 with touchbar be replaced if the jack becomes loose? I’ve already found the parts on ifixit but it is labeled for macbook pro 2016-2017.
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
That machine is covered under warranty. If you attempt repair yourself you will void that warranty. Just take it to Apple.
UPDATE
The audio port is integrated into the main logic board. Repairing it would require miro-soldering skills.
Punteggio 2
1 Commento:
Thanks for the response, Mayer.
My headphone jack is still working fine right now. I’m just asking whether it is possible to be repaired without changing the whole logic board in case the jack breaks down in the future. I had been using a 2013 retina macbook and the headphone jack was the first thing to broke down. For that model the whole board had to be switch out.
Thanks!
da
Aggiungi la tua risposta
Pakanat Decharatanachart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 99
