Salta al contenuto principale
The Vtech Kidizoom Smart Watch DX is a children's smart watch released by Vtech in mid-2017. The watch is designed for ages 4-12 years old, and comes in six different colors, all with the same repair guides.
How do I remove the touch screen from the watch?
I have the back removed off the watch . If I pop out the circuit board am I able to remove the screen and clean it off and remove the moisture that is stuck in there ?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hello, yes it is possible. We had moisture between the display and front screen and could remove it. I just gently removed the white plate at the bottom with a small and thin screwdriver.
Punteggio 1
Be careful not to bend the display component (the white part). The glue holding it in place is flexible and reusable, but fairly strong. While removing the display from the cover, I noticed the display was starting to bend. I got more careful once I noticed, but when I put it back together, the display only showed me a white glow with a black crackle across the middle. I recommend very gently breaking the grip all the way around the edge of the display before trying to pull the display from the cover.
Punteggio 0
Aggiungi la tua risposta
Loreli Evans sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,424
