Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
No Rear Camera or Flash/Torch After Battery Replacement?
I just purchased a replacement battery and followed all the instructions exactly but now my rear camera doesn’t work, it’s iust black. Also, my flashlight doesn’t work anymore. Thoughts?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Did you disconnect the old battery before removing the screen before installation of the new battery?
Punteggio 0
3 Commenti:
Yes I did. I followed all official instructions.
da
It sounds like you have a hardware issue, but I just to be safe have you tried restoring the phone to factory yet? Dont restore from a backup as if it is a software issue, itll copy over.
da
Yes, I have tried to restore it but that didn’t work. I opened it back up again to check the camera ribbon and make sure it was connected properly and everything else looked good. Rear camera is just black and the flash doesn’t function still.
da
Aggiungi la tua risposta
Tyler Burgess sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 72
