Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
1697 Domande Visualizza tutte
Optical drive no power
Hello, I fixed the optical drive roller which was misplaced to fix the CD intake problem, This problem was fixed but I was still getting error with disk reading so I decided to replace the laser kit. I successfully replaced it. I restarted my PS4 but no activity in optical drive. It is not doing anything. Seems there is no power. It seems something got wrong during re-assembly. Not sure how to fix now. Any suggestion and how to check if optical drive is getting power. did any cable got bad?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
maybe you nicked a cable going to the drive , or its a software issue
Punteggio 0
Most laser assemblies ship with a shorting solder connection on the ribbon cable to prevent static damage. Look carefully at the cable on the optics assembly itself for a small “bubble” of solder. Remove this and the laser should work. Since the assembly won’t attempt to spin the disk unless one is detected (laser lights and detects the reflection if a disk is there), it may appear that the assembly has no power. Check for the short and update this with what you find. If you can, post a few pix of the assembly from different angles too.
Dan
Punteggio 0
Aggiungi la tua risposta
lucknow_99 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 66
