Salta al contenuto principale
fans turns constantly 6000 rpm
Yesterday i repair my MBP ( Nvidia Graphic Chip ).
Now he is running but the fans turns constantly 6000 rpm.
it may be that I forgot to connect a cable?
The temp sensors work correctly according to istate pro.
Please help me
ps. sorry for my bad english :)
Questa è una buona domanda?
Punteggio 1
1 Commento
Please explain about repairing your Nvidia chip. Did Apple do this as a recall?
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You haven't given much information to go by, including the readings from iStat.
You may have a process such as a stuck print job causing your processor to run in excess. To find the process: From the terminal type top -u -s3 (to take samples every 3 seconds) and look at the output. This will give you the PID of the offending process. Write down/remember the PID. In the terminal you then enter kill -9 PID number. For example
kill -9 1111
This will kill the process 1111.
Also please tell us the process you used to reset the SMC.
Punteggio 3
1 Commento:
MBP is running.I forgot the temp sensor cabel under the right fan.... Thank @ all
da
SMC reset would be a good start
THIS LINK should hekp
Punteggio 2
1 Commento:
I already made smc reset.did not function
da
You may need to disassemble and clean your heat sinks. When they get loaded with dust and dreck your laptop will run hot. I need to do it every two years or so on mine.
Punteggio 0
Aggiungi la tua risposta
Michael sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,569
