Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Mac Stopped Recognizing Yosemite Boot Partition
Last night, my mac was booted on my Yosemite partition. I left it off the charger accidentally and it died. No big deal, right? So after plugging it in and turning it on again, it boots right to my Snow Leopard partition. Not uncommon, I forgot to hold down option to select the disk. When I restarted and held option, nothing came up and it went immediately to Snow Leopard. I tried command + option + r, option + r, command + option + r, nothing worked. Went to System Preferences, and my Yosemite partition isn’t available to be selected as the start up disk. My computer still recognizes the partition in Disk Utility, and I can access all the files on the drive. I repaired and verified the disks in Disk Utility just to see if that would help, but no luck. I just can’t boot to it. Any ideas?
it is worth mentioning I recently spilt a small small bit of water on my keyboard, leading to a few keys not working anymore (they weren’t keys that were even close to the spill?). However, my command, r, option, and p keys are all unaffected and working properly.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The option on startup should always work, strange. Are you sure your option key is working after the spill? Open a notes program, hold down the option key and just start pressing random keys. If it’s some mess like this (©˙ˆß®∂˙ø¨®å˙ˆ∫´∆˜∑祕ªˆø¨∂ß) then it’s still fine.
I have no idea why I thought of this solution out of all things.
Punteggio 0
Aggiungi la tua risposta
hugh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 65
