Salta al contenuto principale
Guide e supporto per riparazione e smontaggio di apparecchi lavapiatti.
707 Domande Visualizza tutte
Can a damaged dishwasher heating element break something else?
A piece of plastic melted on our dishwasher (66515113K216) heating element, and within a few weeks the heating element failed at that spot. We ran it for a few more months before I ordered the replacement part.
Once installed, the new heating element didn’t work. I can’t imagine multiple things failed at once, unless the fault in the old heating element may have “blown” something else.
I replaced the high limit thermostat as it seemed like the most likely culprit, but no joy.
Before I go and replace every part in this dang thing, I’d like to apply a method to my madness. I do have a multimeter, and both new parts seem to conduct just fine (as does the original high limit thermostat, dangit).
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It was a simple fix, and I probably wasted my money by buying the high limit thermostat. I needed to reset the machine by running the diagnostic cycle. Just pick any three buttons and label them 1, 2, and 3 in your mind, then hit 1-2-3-1-2-3-1-2-3 with less than 1 second between presses. This runs a relatively short diagnostic cycle, and the heating element began working again immediately thereafter.
Punteggio 0
Aggiungi la tua risposta
OteroFam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 207
