Salta al contenuto principale
What is wrong with my iPod, im not sure?
I dropped my iPod on the ground no the bottom half is unresponsive. Can someone tell me what is wrong and how to fix it?
Links on how to fix and items needed would be very helpful.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If the bottom half of your digitizer is unresponsive, take it apart and look at all the connectors and make sure they are seated properly and that the cables do not have any tears in them. If all those should be okay, you may think about having to replace the digitizer. Also, of course, try a rest first and see if that makes a difference. Good luck and let us know what works for you.
iPod Touch 3rd Generation Teardown
Punteggio 2
Aggiungi la tua risposta
Alex Scharkley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 926
