Salta al contenuto principale
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
20 Domande Visualizza tutte
Electric dryer won’t heat
I figured it was the element so I replaced that and it still isn’t heating
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Punteggio 1
10 Commenti:
What should the continuity be?
da
@garet1212 It's either on or off. On, don't fix. Off, replace it.
da
How do I test that though
da
To repeat my answer " A multimeter can be used to test it for continuity".
Digital Multimeter
da
Ok there is two deals on the side of the box that the heating element is in is it the front or back one
da
Mostra altri 5 commenti
Check the circuit breaker for proper voltage using a voltage meter. You should get a reading of 240 volts. If your meter indicates 120v then your breaker is the cause. Usually the Dryer motor will turn but the heating element will not create any heat. If your breaker is working correctly and providing 240volts then the problem is your Heating element has gone bad. By Troubleshooting the circuit breaker you will identify the problem is from the dryer. If you are not familiar with electrical equipment please study up on how to use a voltage meter to properly test your electrical devices ,note If you don’t feel confident with working with electricity hire an electrician to handle the electrical. This has happened to me in the past and by testing the breaker for 240v it usually solves the problem. Take note of the Breaker which manufactureing company is it from. Common brands are SquareD Murray GE Cutler Hammer. They typically are more affordable than the older manufacturers like Zinsco , Federal Pacific . Take the breaker with you to The Home Depot so you can be sure it matches with the new one. Good luck I hope this helps. Be safe
Jeffrey Friend
Update (01/29/2019)
In response to that answer. Your best bet is to contact your local APD (appliance parts dealer) you may also need the High-Limit thermostat and the Thermal fuse which might be the issue. Double check all the connections and roll the Dice.
From the desk of
Tesla
Punteggio 0
1 Commento:
Had a buddy check the voltage yesterday reads right
da
Aggiungi la tua risposta
Garet ricketson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 641
