Salta al contenuto principale
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
201 Domande Visualizza tutte
Fans blowing full blast on MacPro tower. Any way to fix? Solved
MacPro 5,1 Mid 2012 has fans blowing full blast on startup. SMC reset does not fix the issue.
Is there any way of fixing this without going to the Genius Bar?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
I’d run TG Pro to see if I could isolate the problem:
https://www.tunabellysoftware.com/tgpro/
UPDATE
compare mine that’s been running all day with yours
Please note yours is showing a hard drive sensor failure. I’d pull one drive at a time and restart to find the offending one.
Your CPU’s are also running much hotter than mine.
I’m running 2x 2.93 GHz Quad-Core Intel Xeon
Dos-Dude flashed 2009 to 5,1 running Sierra
UPDATE
2671
Single-Core Score
15113
Multi-Core Score
Geekbench 4.3.3 for Mac OS X x86 (64-bit)
System Information
System InformationOperating SystemmacOS 10.12.6 (Build 16G1710)ModelMacPro5,1Model IDMacPro5,1MotherboardApple Inc. Mac-F221BEC8 Memory12.0 GB 1066 MHz DDR3
Punteggio 3
11 Commenti:
Everything green except 4 of the 6 fans. Exhaust, Intake, BoostA and BoostB.
https://i.imgur.com/lBMppeZ.png
da
Interestingly, I removed the Nvidia TitanXP video card so I could run Apple Hardware Test [which wouldn't run for whatever reason]. The system rebooted and is using the stock GeForce GT 120 card. After reboot all fan speeds are back to normal, with the HD temperature sensor appearing to function normally as well. https://i.imgur.com/nhWzqjo.png
The weird thing is that I have several systems with the TitanXP card that don't have this issue with the fans.
da
This system is running 2x 3.49GHz hex-core Xeons. It'll run a tad hotter than most.
da
That appears to be a custom CPU never offered by Apple. How's the GeekBench? (I'll post mine after I run it. (see update above on Geekbench)) Am running a 1TB 860EVO drive. I'm also running a GeForce 120 (second one). Also running one in a 2008 MacPro.
Glad you located the problem. I'm wondering if the card overheating set off the sensors. It might tell us if you installed the card in one of your other machines to see if you get the same results. Here's the only link I found on that card overheating http://www.tomshardware.com/answers/id-3...
da
Yes, the CPUs are custom. SSD is an Apple branded Samsung part originally from a MacPro 6,1.
Looks like the video card wasn't the problem after all, as the fans are still running full blast after I removed it. It ran normal for about 30 minutes before the fans kicked in.
Updated pic from TG Pro: https://i.imgur.com/NAMndAs.png
Geekbench info.
Benchmark Summary
Single-Core Score 2921
Multi-Core Score 20506
da
Mostra altri 6 commenti
Aggiungi la tua risposta
Some Guy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,607
