Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
My internal speaker doesn't work
dear team
i have a problem that broken jack inside my out put 3.5 sound and i couldn’t take it out and the problem now even the internal speaker not working i try every thing rest SMC update software every thing and still showing block its working only in booting the OS
but after that is showing no input
regards
Update (01/25/2019)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It sounds (pun intended) like the operating system continues to think that there’s something plugged into the 3.5mm jack, so it turns off the speakers of your MacBook Pro. The cheap solution is to try to get the plug out of the port. If you do this, definitely deplete the battery/unplug it. Also, don’t keep it charger plugged in. I’d also leave the laptop sitting there for some time to make sure that all power is depleted from the system.
The expensive/safe solution, unfortunately, is to buy a new logic board, depending on your model.
2.5 GHz —> MacBook Pro 13" Unibody (Mid 2012) 2.5 GHz Logic Board
2.9 GHz —> MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board
Immagine MacBook Pro 13" Unibody (Mid 2012) 2.5 GHz Logic Board
Prodotto
$249.99
Immagine MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board
Prodotto
$299.99
Punteggio 0
Aggiungi la tua risposta
ammar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 58
