Salta al contenuto principale
HD action camera with touchscreen LCD, released October 5, 2014.
87 Domande Visualizza tutte
Gopro only works if in the freezer! Hahaha
Gopro in the freezer is the only way I can get it to work. But it only works until it warms up. I replaced the image sensor and it still does it. I tried putting only the battery in the freezer and nothing. Somehow the freezer if fixing it but only for like 2 minutes. Please help. Thank you so much!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Might be a solder connection that has gone bad. As metal expands and contracts in heat and cold, the difference in temperature could cause a solder joint to get a good connection when cold, and loose the connection when hot. Inspect the board with a magnifying glass for any obvious faults. Using a hot air gun you could try to reflow all the solder joins on the PCB. Hope this helps!
Punteggio 0
Aggiungi la tua risposta
Angela Poston sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 208
