Salta al contenuto principale
1005HA LVDS cable: Is 14G2235HA10 equal to 1422-00ML000?
Hi.
Looking for a replacement LVDS display cable for my EEE PC 1005HA. It takes a 14G2235HA10, and I've seen some vendors advertise a cable labeled with both this number and 1422-00ML000. Other vendors use just one or the other of these numbers.
Anyone know whether the 14G2235HA10 and the 1422-00ML000 are exactly the same cable with the same connectors?
The ASUS support site lists only the former number (http://support.asus.com/Search/KDetail.a...).
Thanks for your help.
--Frank
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
My research suggests that the cable is the same but it is based on the information supplied by various vendors I have found on the internet - much like you have. I'd stick to the primary number on the faulty cable and/or the number provided by ASUS
Update
Thanks much, Richdave! I took a chance and am happy to be able to answer this question affirmatively: the 14G2235HA10 IS apparently equivalent to the 1422-00ML000 cable.
Punteggio 4
yes, they are compatible lcd cable
Punteggio 0
Aggiungi la tua risposta
Frank DeSanto sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 10
Tutti i Tempi: 3,513
