Salta al contenuto principale
Il telefono allora al top della gamma Samsung, il Galaxy S8, è stato lanciato nell'aprile 2017.
304 Domande Visualizza tutte
Lost imei and baseband after wrong firmware install.
I have a galaxy s8 european model. I tried to install different model firmware and i lost imei and baseband. Now i cant make calls and my imei number in settings is unknown. Can someone please tell me how can get it back to normal.
Questa è una buona domanda?
Punteggio 2
1 Commento
Thank you so much man
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Look for your “CARRIER_ID: XXX” which you can find when you put the phone into download mode (Power + Bixty + Vol down)
Once you have the 3 letter code that is the CSC (Sales / Region code). Use SamFirm (Download from here) to download the firmware. You can input the CSC code and Phone model (also listed as product name in download mode).
Flash that firmware, you’ll need to flash the non-home CSC to fix the lost imei and baseband so make sure you backup before flashing as non-home CSC will factory reset the phone upon flashing.
Punteggio 2
Aggiungi la tua risposta
Sat paul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,556
