Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Rapid Battery Drain Tristar Replacement
Hi.
I have a iPhone 6 here that is rapidly draining it’s battery in stand by.
100% to 0 with in an hour and a half. All batteries that have been fitted have done this. (Have tested a battery in another phone and it was all good)
I have replaced the Tristar pulling approx 1.2A on charging however the battery drain is still happening a lot slower though. Now it’s taking 8 hours but still no good.
I have replace the WiFi Cap 8 months ago as it was shorted.
Possible Tri star IC no good from new?
Or should I remove re ball and try again?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
An iPhone 6 pulling 1.2Amps sounds a bit too much for my experience. You may try reballing Tristar or replacing it once more but with such power draw I’d look around for shorts too..a full battery drain in 8 hrs should be giving some heat somewhere as a guideline.
Punteggio 1
Aggiungi la tua risposta
Lee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 116
