Salta al contenuto principale
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
103 Domande Visualizza tutte
Wont turn on or charge
I just bought a JBL xtreme 2 weeks ago and i have had zero problems with it, until today when i went to turn it on. It wont turn on anymore, with or without the charger (original charger from box) it wont turn on, the lights are not turning on, it doesnt react to any buttons pressed. The only thing that is working is that i can charge my phone through the usb port , please help :’(
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
I have the same issue too, tried to factory reset but it didn't even turn on a single led.
Punteggio 0
have you found any solutions? I have the same problem
Punteggio 0
Estava pesquisando num representante de reparos e verifiquei que as Xtreme/Boombox queimam mosfets de potência quando usados em volume alto durante a recarga. Esse excesso de corrente causa a queima dos semicondutores e provocam o problema.
Estou buscando o esquema elétrico para verificar quais mosfets são estes e como posso usar equivalentes com potência maior.
Punteggio 0
Aggiungi la tua risposta
viccecool sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 21
Tutti i Tempi: 468
