Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
773 Domande Visualizza tutte
Transfering files from dead MacBook to another MacBook using enclosure
Hi! Recently my macbook (due to water damage according to the apple store) completely died- the tech guy said that they could repair it, but there was no gurantee the data would be all there when repaired so he said I could try and use an enclosure to recover the files (link:https://www.amazon.com/gp/product/B00TQW...)
So I ordered it and followed the steps and plugged my dead mac’s hard drive into it and then the adapter into my sister’s (perfectly fine) computer. However, my files did not show up in disk utility or computer- could it be that my my hard drive is damaged beyond repair and I should just repair my old computer with the files? Or could I have done something wrong or something? Please help!!
Update (01/27/2019)
@mayer @danj @aactech Yes I was careful! It doesn’t show up anywhere- not on disk utility, terminal, or my desktop. Does this mean the files aren’t recoverable? Should I give up and have the apple techs repair the comp and start fresh? My sister has the same mac as me i think, and she was running yosemite and i was running high sierra.
Questa è una buona domanda?
Punteggio 0
6 Commenti
There are a few different SSD's are you sure you got the correct case for your systems SSD?
da
it said that it was compatible with my computer model.. does that count?
da
Hi Lucy,
Were you careful to discharge any static from your hands and not touch any of the circuits when you removed the hard drive and while installing it in the external case?
Did the drive show up in the Disk Utility but just not the files?
If so it may just be corruption of the file structure. If the files are very important a local techie may be able to help you. One with data recovery experience on MAC's!
For others reading this - MAC's are VERY, VERY fussy about parts and are very tricky to service. Unless you are a techie I would not touch them as you'll probably end up spending even more money.
da
what computer does your sister have and what system were you running and what system is she running?
da
@mayer @mike @danj Yes I was very careful! It doesn't show up anywhere- not on terminal, disk utility or my desktop. My sister has a mid 2015 mac and was running yosemite, I was running high sierra i believe.
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hold on! If you where using High Sierra on your system and your sisters Mac running is Yosemite her system won’t see or have any way to access the files from your SSD.
The issue is Apple altered the format of SSD’s in High Sierra! Your drive is running APFS unlike your sisters Mac who’s SSD is running HFS+ under Yosemite and has no knowledge on how to handle APFS.
Your data is safe for now! You’ll need to make a decision here.
Are you planning on getting a new Mac? If you do you’ll then need to make sure its running High Sierra and then you’ll be able to recover your files from your drive. The other option is upgrading your sisters system to High Sierra. Just be careful here as your sister will be pi55ed off if you mess her system up too! ;-}
Punteggio 1
4 Commenti:
Unless the drive is completely dead the files will all still be there . You just can’t see them. see Dan’s reply.
da
@aactech @danj I am going to try backing up my sisters computer with an external drive, then upgrading it to high sierra then using the enclosure to restore the files- do you think this would work?
da
That should work
da
Ya, give it a go lucy.
da
Aggiungi la tua risposta
Lucy jennifer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 111
