Salta al contenuto principale
L'Apple Magic Mouse è un mouse multi-touch prodotto e venduto da Apple Inc. È stato annunciato e venduto per la prima volta il 20 ottobre 2009.
Replace with better laser bulb
This is a shot in the dark. I understand that Logitech has developed this new (2009 - jseus fck!) tracking tech that it calls “Darkfield”, so it can track on pretty much any surface, i.e. glossy or clear glass surfaces.
Anyone know if it would be possible to extract the tracking sensors in a logitech mouse and transpose it into a magic mouse?
I want my mouse to match my mac, but the magic mouse tracking sucks, even after the release of magic mouse 2.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The tracking is really no different in any of the laser mice. All work off of the micro reflections of the surface you are using. The dark field mouse doesn’t track any differently, it’s designed to work on a clear glass surface unlike the other mice. Logitech - Tracking Technology
Dust can interfere with the tracking as well using a cotton swab clean the lens carefully as you don’t want to scotch it either.
As for your direct question swapping the LED units around, sorry just not possible as the plastic lenses and fixture as well as the circuitry are not the same.
I would make the investment for a good mouse pad which has fine textures for better tracking.
Punteggio 0
Aggiungi la tua risposta
Will sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 268
