Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
6S+ Camera not working after replacing it.
My 6s+ was plagued with the shaky tracking issue everyone else has.
I bought a replacement and installed it. Now flash/led does not work and the camera is not recognized by any app. (Black screen). I reopened the phone and reinserted the OEM one… same issue. All connections are tight and everything is replaced as it should be.
I’ve reseated the ribbons 10 times (which each camera, old and new) and restored my phone to factory. No change.
Did I damage the board? I’ve seen a ton of these questions asked but the answers are always “reboot the phone” “reseat the cables”. That’s not the answer here.
What’s my next move?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Unfortunately, it does sound like the board connections have been damaged in some way. Either replace the board, or upgrade your phone is probably your best option. If you already attempted a restore and it did nothing, thats probably the issue.
da
Aggiungi un commento
1 Risposta
If reseting the cables didn’t work, I think the next step would be a new front assembly. Thats the proximity sensor, mic, speaker, and camera.
Punteggio 0
Aggiungi la tua risposta
tdog69697 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 43
