Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1199 Domande Visualizza tutte
I just replaced the WiFi module of the iPhoneX but still poor
Hello everyone. I just replaced the Wifi & bluetooth module (one piece). However both of these components are still causing issues. I’m getting absolutely dreadful signal for wifi+bluetooth where I can’t discover anything past 2 feet.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Hi, it sounds like damage to the part of the chip on the Logic Board, caused during the original disassembly of the wifi module. You can try replacing the module you bought to rule out a faulty part, but repair of the chip might involve skilled micro-soldering.
Punteggio 0
UPDATE: i found the culprit. it seems the connector between wifi ribbon cable + logic board is not staying properly. is there a way to keep the connector down and snapped in? right now im trying to tape it down with electrical tape and RTV to mold over it so when the case is pushed down it will stay down but to no avail currently.
Punteggio 0
the center latch part of the wifi connector on the logic board was snapped off or removed or something when it was last repaired ( bought this phone used). i kind of have it taped down, but i am getting a weird reboot loop every few minutes now. I tried a hard shutdown/start, and also did a factory reset - tried setting to dec 1, 2017 etc. nothing works. it does a weird reboot loop, i had it on all night and then tried using it and it decided to start rebooting.
Punteggio 0
Aggiungi la tua risposta
michael stevens sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 107
