Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
My screen is unresponsive.
I recently got a repair on my phone and after it was continuing to function normally. A couple months after I received a black fade at the top right corner. Then when I attempted unlocking my phone it wouldn’t cooperate. I’d have to press my power button locking it continuously until my phone cooperated. The problem has gotten worse. I’ve tried hard resetting it, factory resetting it, and resetting all the settings.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
More than likely you have a failing screen. If the company who repaired your phone has a decent warranty (6 months or a year) then should be able to get it replaced for free as long as there is no damage to the screen. If that is not the case, youll have to get it repaired again. There are instances where board level issues can cause the behaviors that you have, but more than likely it’s the screen that’s failing.
Punteggio 1
Aggiungi la tua risposta
Laurel Finch sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 42
