Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone 5 stuck on apple logo then shuts down
I have an iPhone 5 which is water damaged so not expecting much! Anyway, when I turn it on, the apple logo stays on the screen for about 30 seconds then the phone shuts down. I am unable to enter Recovery or DFU mode so cannot restore. I’ve noticed it has a replacement battery which could be the culprit but powering it form a power supply gives the same result. I would like to get the data off it for my friend so any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Unless you have a lot of experience doing board level troubleshooting, you best bet at recovering data is to get the phone to an iPhone data recovery specialist. However, if you want to try something yourself first, I would suggest the following:
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no data/no fee policy so you don't have to spend money to find out if the data is recoverable or not.
Punteggio 3
2 Commenti:
I'll give this a shot at the weekend. Not feeling too hopeful but that is for your help.
da
Good luck, it'll be an interesting project.
da
Aggiungi la tua risposta
jamiebrowm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 57
