Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Why does my iPhone 5s keeps restarting after minutes of using it?
Hey guys! So i had my first iphone issue before, my iphone 5s keeps on shutting down and drains its battery after minutes of using it, so when i had that i problem, i keep using my phone while connected to my laptop until it never turns on again. So i decided that maybe my phone needs a battery replacement. I recently had my battery replacement but another issue occurred, my phone keeps on restarting after minutes of using it and the battery logo keeps on changing numbers, after restarting it shows 1% then suddenly changes to 100%. I am planning to visit the technician this afternoon again. What should I do if it still doesn’t work? I hope someone could help me. Thank you!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Was the battery replaced by a repair store or did you do it yourself?
Random rebooting and battery percentage showing 1% jumping to 100% indicates that one of four the small little SMD components right above the battery connector may have been damaged or pried off by accident when unplugging the battery.
This is fairly common when doing battery replacements on iPhone 5 series phones.
Punteggio 5
3 Commenti:
Thanks. My phone is now fixed.
da
How did it got fixed? please help me i have exact same issue.
da
Need to replace missing or desolder dislodged component right above battery connector.
Will need phone taken to someone that does microsoldering or board repairs.
da
Aggiungi la tua risposta
Coddie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 522
