Salta al contenuto principale
At the 2004 North American International Auto Show, Nissan unveiled a completely redesigned Pathfinder for the 2005 model year.
14 Domande Visualizza tutte
Why my 2012 Nissan Pathfinder loses brakes completely on the road?
Hit a pothole 8 months ago and lost use of brakes entirely for a few minutes, Eventually brakes recovered after continuous pumping of brake pedal. Since then it has done it several times while driving without even hitting potholes or any uneven surface on the road. Have serviced four wheels and replaced Master Cylinder and it still happens.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would have a mechanic check your break lines, and maybe a search to see if there is some sort of sensor for your ABS
Punteggio 0
1 Commento:
There are four sensors, one on each wheel. Then there is the ECU which controls the ABS breaking process. Nissan Dealer has checked all of that but has revealed nothing out of the ordinary. When this problem happens not even the brake malfunction light on the dashboard lights up…. Poltergeist?
da
Aggiungi la tua risposta
Julio Lynch-Lorca sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 329
