Salta al contenuto principale
Il Samsung Galaxy S8+ è la versione maggiorata del telefono al top di gamma Samsung. Lanciato nell'aprile 2017.
How to flash format
How to flash format demo unit
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
So fair warning before I continue these phones do not operate with a sim so you will not be able to use cellular. If you are hoping that formatting it will give you a fully functioning phone then you’re gonna have a bad time. Also the demo software can sometimes be hard coded in the phone and you may need to find a way of force removing that (it can depend on where the demo was from ). That being said here is an awesome walkthrough for that you may need to format the phone.
  1. Ensure the device is powered off.
  2. Press and hold the Volume Up + Bixby + Power buttons at the same time. Release all buttons when the Phone vibrates.
  3. From the Android Recovery screen, select Wipedata/factory reset.
  4. Select Yes.
  5. Select Reboot system now.
Punteggio 0
1 Commento:
hello and thanks for the info upfront.
but whan i try that it wil not go to the android recovery screen with the combo bibxy vol up and power buttons at the same time. how can i still do the wipe data factoryt reset?
da Condividi
Aggiungi la tua risposta
Faisal sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 1,765
