Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
678 Domande Visualizza tutte
After replacing housing apple pay not working
Hy,i have compleately reasembeled iphone 8 plus
all looks to be working,wifi bluetoot wireles charging all works. But apple pay is not working. Any ideas how could i fix it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sostituzione gruppo connettore Lightning iPhone 8 Plus
Check step 51, there is a thin flex cable going around the top right perimeter of the rear housing, around the rear camera position, that is the Apple Pay antenna. It needs to be screwed in to the rear housing and a screw post on the logic board.
Also all the small clips, brackets, screw holes and contact points on the rear housing may serve RF purposes, make sure they are exactly prepared and assembled like factory condition.
Punteggio 3
1 Commento:
Does the iPhone use the NFC for automatic setup? i mean when you bring an old device close to a new one and it automatically sets it up using the old device settings
da
Aggiungi la tua risposta
Justas Gurauskas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,792
