Salta al contenuto principale
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
61 Domande Visualizza tutte
Can I use the glass and battery from a mini 2 on a mini 1
I recently found a iPad mini 1 in a recycling center. The battery is a bit bloated and the glass is cracked. Can I use the glass and battery from a mini 2 to fix the mini 1? I dont need the LCD just the glass. Thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Ethan, yes you can, the IC chip is the same one from the iPad Mini 1. Therefore, you can use the glass. However, the battery is not compatible.
Punteggio 0
Aggiungi la tua risposta
Ethan Leroux sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 396
