Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
No Airport card installed issue iMac
So I just got done installing a 256GB SSD into my iMac 27" 3.4Ghz i7 that I just got and it has a 2TB on the 3.5 slot and everything boots fine and works good but No airport card installed is showing up. So I tried to reset my P Ram by Alt + Option + P + R and also unplugging power and hold down the power button to reset and also I just double checked connection with my wifi card to make sure its inserted property but its still showing no airport card installed...
any help would be great...
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Go under the Apple in the upper left hand corner to "about this Mac", more info, network, Airport and see if the computer sees the card. If not, take the card out then reseat it, replace the cables and check again. If it still fails, replace it.
Punteggio 2
Aggiungi la tua risposta
mywapple sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,164
