Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
6S Plus Rear Camera - Left side not focussed
6s Plus, restored via DFU, the camera is shaky (I know this is a known issue with the OIS) and I have replaced the camera, the replacement did exactly the same so either something else is wrong or I got a dodgy camera.
However, I’ve noticed that the camera has no problems focusing close up, within 10 inches or so, however when focusing over 3 feet it struggles to focus (when its not shaking!), the left side is extremely blurred but the right side is actually in focus.
wondered if anyone has come across this? I’m reluctant to change the camera again
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Indeed, this could be a bad replacement camera…or a logic board issue. The challenge when troubleshooting iPhone issues is that you need to have access to high quality, known good parts. Unfortunately, Apple doesn’t want to play ball here and refuses to distribute high quality replacement parts to third party shops. Some vendors, like iFixit, do a tremendous job at quality control but the whole “iPhone replacement part” ecosystem suffers from crap parts noodling their way through the supply chain.
Beyond trying another camera, my feeling here is that one of the many voltages used to power the camera and the OIS system may be damaged. A little probing would confirm this possibility so if you have a local shop that does micro-soldering work, they may be able to help out.
Punteggio 3
Aggiungi la tua risposta
Josh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 55
