Salta al contenuto principale
Modello A1419 / EMC 2806 / Fine 2014 o metà 2015. Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (ID iMac15,1); EMC 2834 fine 2015 / Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (iMac17,1) Tutti con display Retina 5K.
573 Domande Visualizza tutte
Black Screen and Loud Fan
This iMac is under 3 years old and have never been serviced. The black screen issue started when I tried waking it up from sleep. When I tried to restart it I can’t get the screen to show anything. I’ve tried resetting the NVRAM (the second chime is like coming from a tiny speaker, is this normal) and the SMC. When i tried to run diagnostics that’s the time the fan started getting loud
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Resetting the SMC will sometimes cause the fans to race for a short time until the system fully boots up.
Are you able to see any light from your display when you start your system?
Try taking a flashlight held against the screen to see if you can see your desktop and its icons, are you able to see them?
Punteggio 1
Aggiungi la tua risposta
rhoderick.bocobo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 85
