Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
Sleep sensor problems / Battery connector, possible water spill?
Hi there ifixit-Team,
my macbook stopped functioning properly. Maybe there was a water spill - I'm not sure though, since the water spilled was pretty far away from the notebook and the notebook was turned off for a few days.
Similar to this problem: when I try to boot the computer, it automatically goes into hibernation mode after a few seconds. Each time I press the power button, it will continue the (existing) boot for 3 seconds, then the backlight will be turned off and it goes back to hibernation - I can continue doing this and even get to the desktop.
After a little bit of reading I have removed the Sleep sensor and the battery and the computer works again, but I noticed some strange marks at the contacts of the sleep sensor and a burnt smell. Since a notebook without a battery isn't very practical, this isn't a great solution ...
Here are some photos of the board with the removed battery conector / sleep sensor: #1, #2, #3 close up. To me it seems like one or two of the contacts have molten, since the copper goes over the engraved letters (BAT/S?P SW) ... or is this supposed to look this way?
Is there anything I can do? Should I try to scratch away the copper on the board so the contacts won't be connected to each other?
Thanks for your help!
Questa è una buona domanda?
Punteggio -1
1 Commento
Thanks for the advice and the examination of your board, mayer! Since I'm living in Germany, I won't be able to send it to DT&T. I'll try to clean the board from the metal and see what will happen.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I had this problem with a macbook logic board. I sent the LB to a shop in Peterborough, Canada where it was repaired for $200. They restored the battery/sleep board socket. The board 20 pins were glued inside the socket but it worked fine. Don't know what kind of glue they used.
Punteggio 2
Risposta Più Utile
I took a look at your type of logic board. There is no metal on the surface of mine. Yours has certainly been burned. There is a connector chip on the other side I would like to look at. As for trying to repair yours, I'd clean off all that metal. I don't hold out much hope for this board. DT&T services might be able to repair it for $250: http://www.dttservice.com/macbook.html
Punteggio 3
Aggiungi la tua risposta
Jonas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,702
