Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Domande Visualizza tutte
Black screen with chime
I have a late 2008 MacBook Pro.
I was having problems with the speakers sounding distorted and I read online about a fix you can do with rubber cement.
I followed a guide on iFixit's website and put the glue on the speakers as I saw others do online. I waited a few hours and put the computer back together. At first it seemed like it worked, the speakers sounded great and I had no issues.
Later, in the day I moved my laptop and set it down and the WiFi suddenly stopped working. It said something like "WiFi: No Hardware Installed". I did turned the computer off and opened it up to make sure nothing was loose or looked unusual.
I then did some googling and tried a few fixes (resetting the NVRAM & SMC). I tried to turn the computer on again and it made no difference. I turned it off and turned it on again a few days later when I had time and now the computer won't even turn on.
When I hit the power button it sounds like it's turning on and it does the "chime" noise but the screen remains black. I've tried a few things for this as well (PRAM & SMC reset) and nothing makes a difference.
I think I obviously messed something up when I tried to fix the speaker but I don't know what or if it's fixable. Any help would be greatly appreciated.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Which speaker did you fix?
da
Aggiungi un commento
1 Risposta
I can’t see anything you would have touched in taking the speaker out that would have caused a full failure as you described.
Is the battery tester telling you the battery is charged?
Frankly, I tried sealing up the speaker membrane that was torn on a few systems it didn’t last. I think you should consider just replacing the assembly.
Punteggio 0
Aggiungi la tua risposta
Chelsea Dietrick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 40
