Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Why does my camera still freeze after change
Hi!
I'm quite new to phone reparations but still wanted to give this a try.
So my problem is that the front camera didn't show any image on the phone before I replaced it with a new one. However it still doesn't show any image.
The replacement was front camera, sensor etc.
So the question remains to what the problem is.
Once again I'm quite new and would love tips and what to try and check what's wrong. iPhone 6 is the phone.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
First, I would check if your other top components work, such as the earpiece speaker. If so, the flex cable is probably okay, but there could be some pins damaged either on the flex cable itself or the logic board connector. I would disconnect the flex cable from the board, maybe spray some canned air on it, then reseat it. Either you need a flex cable replacement (whole top components), or the logic board has a short / broken pin.
Punteggio 0
1 Commento:
I Will try and check that when I got time this weekend. Thanks for the replay for now.
da
Aggiungi la tua risposta
Jack Plumeyer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 20
