Salta al contenuto principale
Released July 12, 2002. Identified by model number K45SSWH.
33 Domande Visualizza tutte
Spark while replacing brush and now the mixer won't turn on
Messed up while putting the brush spring back into the side of the mixer and left the power on. While inserting the brush head there was a pop and spark. Now when I insert the brush head (double checked the orientation) the motor still won’t turn on. Guess that means I shorted something, but is there anything I can do to fix it from here?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Just looked up owners manual. This has a dimmer style speed control, since it’s a dc equivalent motor design (brushes are clue). Dollar to a doughnut you burnt the triac (power controlling “transistor”). Disassemble to remove board, a fairly large 3 lead part will have a “crater” in the middle. Replace the board (or the triac if familiar enough) and ‘mem not to play with power attached.
Punteggio 1
1 Commento:
Could you share a picture of this part?
da
Aggiungi la tua risposta
Stephen Head sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 438
