Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Why my battery draining fast and phone gets warm
Why my ip 5s phone draining battery so fast even known good battery i think something shorted out the phone charges battery well but something strange when its turned off ,its not automatically boot when connected to charger i should push power button 1st then it detect the charge. Is it u2 defect symptom?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Has anything happened to the phone recently, such as a drop, repair attempt or water damage? Battery drain can be caused by a defective battery, broken charge circuit or defective peripheral (screen, camera, sensor, flex etc.) . Depending on the history of the device, it could be anyone of those causes.
If you have tried a known-good battery, then try a known good screen to see if that helps. If not, progressively remove peripherals until the problem is identified. Eventually, you may have only the logic board left which would point to a logic board issue.
Punteggio 1
2 Commenti:
I already tried changing battery,lcd,front camera flex,home button flex i will try changing port later
da
And why my iphone didnt turn on immidiately when it connect to power is it board issue?
da
Aggiungi la tua risposta
azmi muwahid sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 58
