Salta al contenuto principale
Lanciato il 3 marzo 2017, Nintendo Switch è un dispositivo palmare che può essere usato con la TV o in movimento.
How to fix Bluescreen?
I saw on reddit a post that i have to change the “m92t36” on the motherboard. Does this really fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione prescelta
Unfortunately, I’ve not found that changing that chip will fix the problem with a blue screen issue.
Punteggio 2
2 Commenti:
How do you fix a blue screen?
da
I wish I knew. Nothing I've tried has worked. If I knew how to fix it I would have posted that here. I was trying to help the OP as much as I could with the info that I had.
da
I have it and i left it on charge next day i went to turn it on and i got bsod
Punteggio 0
Any updates on the repair of bluescreen?
Punteggio 0
Aggiungi la tua risposta
Waldemar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,283
