Salta al contenuto principale
Released in March 2016. Model SM-G891A.
18 Domande Visualizza tutte
Will a repair kit for a Samsung S7 work on an S7 Active?
I need to replace that battery on my S7 Active, but I don’t see any kits for the active—just generic for the S7. Would that work? I’m specifically wonering whether the waterproof seal would fit—is it the same size?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
They are not compatible, kit can be found here: https://www.repairpartsplus.com/Samsung-...
As for the waterproof seal, you can't use the same as the S7. eBay is the only place I could find the precut adhesive strips here: https://www.ebay.com/itm/Samsung-Galaxy-...
Punteggio 0
Thanks for the information. Ths seems like something that should have been easier to clarify. Maybe the folks at iFixit should consider adding a specific notice about incompatibility to the results of searches for S7 active parts.
Punteggio 0
Aggiungi la tua risposta
r torrance andrews sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 145
