Start by looking in the user manual. If you’ve lost your manual, go to this link for a PDF: https://mackie.com/sites/default/files/P...
In the manual, go to the “Troubleshooting” section and look for the heading ‘No Sound’' for some simple checks to perform, e.g. to see whether the speaker set has power & whether the problem is just in one speaker (in which case it could be a bad cable).
If no joy, and you’re still under warranty, the next page gives instructions for pursuing repair under warranty. If you’re not under warranty, you’re faced with a more difficult situation. For more expensive Mackie speakers & gear, helpful info is available such as block diagrams, schematics, etc.; but for your speakers, this doesn’t seem to be the case. It could be something relatively simple, but if you don’t have electronics repair experience, it might too much for you.
If there’s a local repair shop near you that works on things like stereos, amps, TVs, etc., it’s possible they might be able to fix it for a reasonable cost - again, if the problem is something simple, which it probably is.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
