Salta al contenuto principale
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
Game will not load, gives an error
Games will not load on my son's DSI. Gives you the message that you need to hold the power button down and then refer to the owners manual. I do not know where the manual is. He has tried the game in his DS Lite and it worked, this is not a downloaded game it is a game we bought that has worked before now.
Thanks
Questa è una buona domanda?
Punteggio 1
2 Commenti
Thank you for the advice, we will try these!
da
I have pokemon platinum game for dsi and when I put it in and play it, it says error.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
try cleaning the gold contacts of the game and the DSi with a cotton tip dampened with ethanol, methanol or similar and then allow to dry.
Punteggio 1
Hey, the Wifi Board in your Dsi has gone bad or has disconnected from the motherboard.
Very Common error in the Dsi and Dsi XL. When the machine takes a fall the wifi board will come loose.
Remove the back cover and you will see a small board connected to the motherboard. Just make it is connected to the board. If it is, then the board may have gone bad.
Punteggio 0
How can i trouble shoot without the manuel
Punteggio 0
Aggiungi la tua risposta
Wendy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 7,262
