Salta al contenuto principale
Processore A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 o 3.6 GHz quad-core i7. Rilasciato l'8 giugno 2017.
176 Domande Visualizza tutte
Will This Set-up Work and Will it Overheat?
Hey guys!
I’ve read and went over some great tear-downs from multiple sources via this forum and would like to get some clarification!
I plan to do an upgrade on my iMac again and as the title stands… I was hoping for some feedback.
Current Setup:
  • 250 GB SSD
  • 2x16 GB (32 GB total) RAM
Final Setup:
  • 256 GB SSD Blade
  • 2 TB SSD SATA
  • 2x16 GB RAM (keeping it)
  • i7-7000 or i7-7000k (opinions are welcomed)
Please let me know what you guys think! Thanks in advance.
Questa è una buona domanda?
Punteggio 0
1 Commento
Your systems specs: iMac18,2
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Installing the SATA SSD will require a SATA cable and the mounting hardware (rubber mounts) It’s a bit of work as you’ll need to lift the logic board out to gain access to the logic board connection point for the SATA & power cables (Purple).
As far as the CPU you’re limited to what Apple used in this series, the best you can go with is a I7-7700 3.6 GHz.
You’ll need to follow this IFIXIT guide to put the drive in: Sostituzione Disco Rigido iMac Intel 21.5" Schermo Retina 4K (2017) And heres the parts you’ll need:
Make sure you use the correct tools and follow the IFIXIT guide! If you don’t, you have a good chance of damaging your display which would be an expensive mistake!
Immagine iMac 21.5" (Late 2013-2017) SATA Cable
Prodotto
$12.99
Punteggio 2
2 Commenti:
Hello Dan! Thank you for the feedback!
My main concern is the SSD Blade. Do you personally feel like it's a good investment to upgrade it?
Here's the SSD Blade I've been planning on purchasing: https://beetstech.com/product/solid-stat...
Merry Christmas and Happy Holiday!
da
I personally prefer going with the PCIe blade drives as it offers better performance than the SATA interface.
But! Not all 21.5" iMac's have the needed component support populated on the logic board. So while it would be ideal, it may not be an option for you. For reference: iMac 21.5" 3.0 GHz i5 (4K, Mid-2017)
"*This model has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive. If configured with a "Fusion" Drive or an SSD at the initial time of system purchase, it also has a PCIe connector, but this connector is not present if the system only is configured with a hard drive."
da
Aggiungi la tua risposta
Bryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 60
