Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1199 Domande Visualizza tutte
iPhone X occasionally reboot and overheating - Water Damaged
Hey,
I’m currently working on a Iphone X, which has been a victim of water damage (Not salt water) some time ago. The phone shows unnatural behaviour such as randomly shutting off, attempting to reboot, however ends up boot looping. If you leave the phone for some time after the boot loop, it will turn on normally. Quite frequently, when playing games or doing anything that requires more ‘power’ from the cpu, the phone will become decently hot in the area of the motherboard. Can mostly be felt on the back glass of the Iphone. Sometimes I could go about 2 days, without having any problem with the phone. I would just like to point out that the battery hasn’t been replaced after the water damage situation.
Upon inspection of the device, is has got some severe rust near charging port, taptic engine and loudspeaker. There has also formed water crystal within the original OLED display. Besides that nothing really stands out.
Usage wise the phone is capable of all the usual tasks, such as wifi, bluetooth, 3d touch, play sounds, front and rear facing cameras, FaceID, buzz and much more.
The thing I have been wonder about, is if all these affected components could cause a short or if the main motherboard itself, has been damaged from the water. Before beginning to take the motherboard apart, I see someones expertise and advice, to maybe resolve the issue and pin point the problem.
I have provided images and videos below, to get a better understand of the defekt and how the phone currently operates upon startup. Thanks in advance for your help!
Hardware inside of the iPhone X:
Spot on the OLED display, affected by the water:
Normal boot up of the iPhone:
https://drive.google.com/file/d/1JGbPh0k...
The occasionally boot loop:
https://drive.google.com/file/d/1QKKHSxe...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
With water damage, all bets are off. You are already experiencing a variety of issues and this will likely get worse with time. Thoroughly decontaminating the logic board on an iPhone X is especially challenging because of the sandwiched approach to the board. If water got inside the two layers (most likely) then you would have to separate the those layers in order to do a proper job. This increases the complexity exponentially.
To be brutally honest, for a water damaged iPhone X, you should only aim to recover the data and make no other promises unless you are an advanced micro-solderer.
Punteggio 4
2 Commenti:
Hey,
I know it would be a difficult job to separate the to two layers and look for a potential issue within the motherboard. I took the motherboard out of the phone and inspected it under a microscope, where I couldn't see any signs of waterdamage on the top layer. I also checked for any shorts on the 3v0_nand line, which is a line near the edge of the motherboard, vulnerable to any water leaking in from the side of the phone, however, there were none.
I have all the right equipment to potentially fix this motherboard, however, the only thing I'm wondering about, is if the rusty components could have any affect on the motherboard and possible cause shortages.
Thanks for your replay btw.
da
Considering the corrosion at the bottom of the phone, I would try a replacement charge port flex to see if that helps. Otherwise, you'll have to open the sandwich and probe all of the PMIc outputs.
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
da
If there wasn’t corrosion on the board itself I would say start by troubleshooting what components starting to fail. But u do have it so i’d say replace the mobo and moveon they aren’t that expensive. Especially since its not the current model. But if u wanna still use a mobo that has corrosion already then go ahead. But for me when the board has corrosion it now has an expiration date as to when it will fail.
Especially when u take into the account the extreme things a phone needs to do daily. So I wouldn’t risk it personally but its your choice in the end.
Punteggio 1
Aggiungi la tua risposta
Kevin Pielak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,977
