Replacement home button cable
My home button cable are broken so my friend buy this for me
how i can install this under shield plates?
Questa è una buona domanda?
The image you linked is for an iPhone 6 plus. Is your phone an iPhone 6 or 6 plus? The length of the cable are different between the two models.
You’ll need to pull the old one off, you can tear the little heat shield sticker off along with it if you want. To put the new one on you’ll have to align and fit it with the holes provided on the back plate. Once you’ve aligned it use sticky tape (scotch tape) to keep it in place. The home button connector end should have adhesive behind it’s metal plate.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 41
