Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
fault code 4SNS/40000000/Th1 stored
Hi, couple day ago my Macbook starts shut down randomly and freeze after wake ups. Ran Hardware test twice- same fault stored
4SNS/40000000/TH1
googled fault code- looks like thermal sensor problem
installed SMSfan control- CPU temp around 60 celsius- fan speed 1800 rpm
What does it mean? is it fixeble?
Thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
TH1 should be the sensor on the heat-sink IIRC
You may simply have a clogged heat-sink, faulty fan or need to renew the thermal compound on the heat-sink. It could however be a faulty sensor.
HIH
Punteggio 3
1 Commento:
Thanks,
just re-installed heat sink, replaced thermal paste. Found damaged connector on one
of sensors( from previous repair). Performed hardware test again the same fault ... now looking for new
heat sink with fan
da
Aggiungi la tua risposta
Vitali sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 476
