Salta al contenuto principale
Modello A1286. Lanciato nel febbraio 2011 / processori quad-core Intel Core i7 da 2,0, 2,2 o 2,3 GHz
586 Domande Visualizza tutte
Need one replacement (short) screw for bottom cover?
After upgrading RAM, I was replacing the bottom cover, and one of the short screws went flying. Can you tell me the size, and ideally a source?
I see that iFixit has full screw kits, but they are $60 and out of stock besides.
Thanks,
Tom.
Immagine MacBook Pro 15" Unibody (Mid 2010 - Mid 2012) Screw Set
Prodotto
$49.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I may be wrong but suspect it is a 3mm long Phillips screw and expect it's the same thread size as the longer (13mm) screws.
The screws appear to be a M2 thread with a #00 Philips head
EDIT
A quick search of eBay with "macbook screw A1286" shows a few kits for around $20.
HIH
Punteggio 2
3 Commenti:
Richdave: this was very helpful, thanks! I'm pretty sure you are right about the size. I ordered some 3.5mm screws and will provide an update once they arrive.
Thanks again!
da
How did you make out?
da
My long-overdue update: the screws I ordered worked fine.
da
Aggiungi la tua risposta
Tom Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,244
