Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
4 Commenti:
Define "exposed to water". Are we talking about a drop or two or water landed on the screen, someone spilled beer on it, or it took a dive in a swimming pool?
If it has water damage you should either take it apart yourself or take it to a reputable repair shop for a water damage treatment. Also if it was dropped in the toilet let someone know that before they touch it, you would want to know first.
If battery had some charge quite a bit of troubles might have been started as soon as water reached the connector, starting from battery charging and power supply circuits, main power IC and so on, depending on how much water reached in and the battery power. Most probably screen is also in a bad shape.
da Steve
da darklotis19
Home sprinklers opened up on it in a garage fire, and soaked it.
da Allen Henry
da arbaman
