automatic transmission not shifting
transmission not shifting properly
Questa è una buona domanda?
First thing: check your fluid if you haven't already. Lack of fluid or worn out fluid can cause automatic transmissions to fail to shift properly.
I don't know what the specific steps are for a Dodge Caravan but there should be instructions in the owners' manual. Usually it involves something like the following:
The above steps are something like what's required on some Chevy trucks. Some vehicles require checking while the engine is off but most, I think, require a hot check while the engine is running. I could be wrong. Check your manual.
If the fluid level is OK, sniff it (don't burn your nose!) and if it smells "burnt" then it could need to be changed. Auto transmission fluid changes are usually kind of messy so you might want to have this done somewhere.
If the level is low then you need to either look up the type of fluid it needs and add some (check the manual again) or take it to a mechanic to get it topped up.
Good luck!
Getting a check for codes is a good idea too but a fluid level check is a quick no-brainer test to rule out a really simple problem first.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 11,496
My recommendation would be that you try a place like Autozone or your local mechanic and have it hooked up to an analyzer. It is very difficult to diagnose since there are lots of reasons why your transmission does not shift right
da oldturkey03
