Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Unresponsive spot on screen
I have changed the screen, and no luck still. There is a small portion of the screen that doesnt react to touch, and haven’t been able to fix it. Also checked rechecked connections with screen cables and changed the battery, no luck still. Any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
This is very likely a problem with the touch ic chip…which requires mad skill to repair.
Jessa Jones is very good at this kind of repair. She owns the website irehab.com. She is well known amongst ifixit soldering members. I don’t know how much she would charge to repair a 5s. I’m not saying this is what it is,but it very likely is.
you could always try to replace the screen again. Also,you can factory erase the phone,and even reinstall the iOS. It could be a software issue. I’ve heard of touch issues such as ghost touch and non functioning touch. This is very often caused by that ic chip(the chip responsible for controlling touch on the logic board). I’m sure Jessa could repair it.
Good Luck!
Punteggio 0
2 Commenti:
I forgot to ask...I’m assuming yes,but is the non touch part of the screen in the same place on the replacement screen?
da
Yes it is. Thank you for your feedback, i will keep that in mind.
da
Aggiungi la tua risposta
Jere sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 48
