How to fix a bent back of ipad min?
Accidentally bent the ipad min a little bit. It now gaps a little bit on both side. How do I get it to refit the ipad mini?
Questa è una buona domanda?
At minimum, remove the digitizer and LCD, then use a tool such as the gTools PanelFormer Pro to coax the frame back into straightness, then put the LCD and digitizer back in.
That is a delicate tool to use to fix aluminum housing, I would just slowly bend the frame and straighten it out with bare hands (with digitizer/LCD and logic board removed of course).
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 554
