Salta al contenuto principale
Il Westpointe MDC 45AE è un deumidificatore importato da Midea American Corporation.
Samsung Type Air Conditioner?
Air Conditioner Type Samsung when operated on the hot mode does not heat up .... Just keep the sound output operation without interest
Immagine
Questa è una buona domanda?
Punteggio 0
6 Commenti
Please reword your question as it is hard to understand.
da
Please reword your question as it is hard to understand \\\\\ thank you
da
ok You have formulated the question whether this method is understandable
da
@alqudah
your unit a cooler and a heater? It does not heat up? What make and model is this unit? What is your native language?
da
@oldturkey03
your unit a cooler and a heater ? yes \\\ It does not heat up ? yes \\\ What make and model is this unit? i'dont no \\\ What is your native language? arabic
da
Mostra 1 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
@alqudah
this unit looks like a split inverter unit. You need to let us know if there is an outdoor unit connected to it. Let us know if this unit heated before. You want to start checking the thermostat and the temperature sensor.
Post a clear picture of these areas
Google Translation
هذه الوحدة تشبه وحدة الانقسام العاكس. عليك إخبارنا إذا كانت هناك وحدة خارجية متصلة به. دعنا نعرف ما إذا كانت هذه الوحدة تسخن من قبل. كنت ترغب في البدء في التحقق من الحرارة ومستشعر درجة الحرارة.
hadhih alwahdat tushbih wahdat alainqisam aleaks. ealayk 'iikhbaruna 'iidha kanat hunak wahdat kharijiat mutasilat bih. daena naerif ma 'iidha kanat hadhih alwahdat tusakhun min qablu. kunt targhab fi albad' fi altahaquq min alhararat wamustasheir darajat alhararat.
انشر صورة واضحة لهذه المناطق
ainshar suratan wadihatan lihadhih almanatiq
Immagine
Punteggio 2
Aggiungi la tua risposta
hamzah sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 23
Tutti i Tempi: 505
